| [TUB][QUESTION]Embrayage Hydrolique | |
+6orsu2b buellman626 pingouin Buell-LN GILLESPONS seby 10 participants |
seby
Nombre de messages : 1034 Date d'inscription : 12/07/2007
| Sujet: [TUB][QUESTION]Embrayage Hydrolique Lun 9 Juin 2008 - 17:16 | |
| Salut, Quelqu'un a deja monté/vu ca ? vous en pensez quoi les pro? http://www.americansportbike.com/shoponline/ccp0-prodshow/A9154.html A9154 - Hydraulic Clutch Conversion Kit Magura Hydraulic Clutch conversion. Fits all 96 and later Buells (except 96 S2). Complete kit includes Master cylinder with adjustable lever and mirror perch, Slave cylinder with bleed valve, and a small diameter easily routed hydraulic line. Easy to install, interfaces with your existing ball ramp mechanism. Only requires the removal of the clutch inspection cover, not the primary case cover. Smooth frictionless feel that stays consistent, as opposed to cables that get stiffer as time goes on. Reduces clutch pull effort. Includes the electrical switch so that in-gear starts with the clutch in are as normal. Includes the bleeder kit with fluid. Note: Tube frame clutch conversions will have a silver master cylinder as shown. XBs will have a Black Master cylinder. Note: This clutch perch is not compatible with CityX/Ulysses Hand guards at this time. Note: Not compatible with Banke Shifter pivot block without modification. Price: $259.95 |
GILLESPONS
Nombre de messages : 158 Age : 52 Localisation : MANOSQUE Date d'inscription : 03/05/2008
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Lun 9 Juin 2008 - 20:49 | |
| salut Mec,
t as rien d'autre a faire que te compliquer la vie.....????
VA ROULER???? !!!!!!!!!!!!!!!!! MAN |
Nombre de messages : 3993 Age : 63 Localisation : Bourgogne, sur la côte des grands crus Ma Buell : ex S1 1997 Date d'inscription : 31/08/2006
pingouin
Nombre de messages : 1062 Age : 54 Localisation : col de l'arzelier 38 Date d'inscription : 06/09/2006
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Lun 9 Juin 2008 - 21:19 | |
| disons alors oleohydraulique ! |
seby
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Lun 9 Juin 2008 - 22:04 | |
| - GILLESPONS a écrit:
- salut Mec,
VA ROULER???? !!!!!!!!!!!!!!!!! MAN bah tu sais quoi, tu te coupes les mains, pour en avoir des aussi petites que mois, et pis on en reparle qd t'aura choper des crampes ... |
Nombre de messages : 22317 Age : 64 Localisation : Beersel (.be) Ma Buell : X1 Red Racing Stripe 626/80+MTS DVT 1200S+Diavel 1260S
Nombre de messages : 12643 Localisation : Corse Ma Buell : XB12S 2004 Red
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Lun 9 Juin 2008 - 22:44 | |
- salut Mec,
VA ROULER???? !!!!!!!!!!!!!!!!! MAN bah tu sais quoi, tu te coupes les mains, pour en avoir des aussi petites que mois, et pis on en reparle qd t'aura choper des crampes ... Tu as quoi comme taille de gant ? du 6 1/2 ou du 7 |
seby
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mar 10 Juin 2008 - 8:09 | |
| Segura SEG600..... taille 6 >< En + j'utilise la moto ts les jours, et a Lyon , transmision EU, bah faut jouer de l'embrayage souvent . Mais c'est pas ca qui m'empechera de rouler au pire dans 1ans, je pourrais casser des noix avec la main gauche |
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mar 10 Juin 2008 - 8:12 | |
seby
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mar 10 Juin 2008 - 9:01 | |
seby
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mar 10 Juin 2008 - 10:08 | |
| La nature est bien faite, j'ai 2 mains et je suis assez costaud J'ai bon? Seby |
seby
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mar 10 Juin 2008 - 10:09 | |
| - buellman626 a écrit:
- Petites mains, grande g***...
NAnnnn, petites mains, grand b*** "TU SAIS CE QU'IL TE DIT LE CASSIS" Seby, petit mais costaud ! |
Buell X1 2001
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Jeu 12 Juin 2008 - 13:23 | |
| et si tu prenais simplement des leviers différents; sans prendre directement des machins comme ça? |
seby
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Jeu 12 Juin 2008 - 14:12 | |
| ouais, je pense que c'est ce que je vais faire Levier réglable + le machin easy clutch. |
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Jeu 12 Juin 2008 - 15:17 | |
| - seby a écrit:
- ouais, je pense que c'est ce que je vais faire
Levier réglable + le machin easy clutch. j'ai mis sur mon site un tuto pour monter l'easy clutch.Je l'ai depuis trois ans et tu peux pas savoir la différence après l'avoir installé.50% de facilité en plus |
seby
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Jeu 12 Juin 2008 - 15:58 | |
| m.p. |
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Jeu 12 Juin 2008 - 16:19 | |
| - seby a écrit:
- m.p.
je rajouterais par rapport à mon tuto qu'il faut une fois la pièce couleur or remontée et le pas inversé revissé à fond le redévisser d'un quart de tour |
gebe44
Nombre de messages : 1218 Age : 61 Localisation : NANTES Ma Buell : Vendue, passé à l'ennemi Date d'inscription : 06/06/2007
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mer 9 Juil 2008 - 14:56 | |
| Ca peut peut-être servir, je ne sais si cela a été posté ailleurs, mais JP m'a indiqué qu'il mettait du "Power clutch" sur Harley, ça marche aussi sur les Buell, l'embrayage devient du velours... entre 30 et 40% de moins. C'est un allemand qui a développé la pièce et a obtenu un prix pour son innovation... Ca ressemble à la pièce de Remy...
http://www.partsmag.com/0503/Drag-Muller-Ed-0503/Drag-Muller-0503.html |
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mer 9 Juil 2008 - 15:41 | |
| - gebe44 a écrit:
- Ca peut peut-être servir, je ne sais si cela a été posté ailleurs, mais JP m'a indiqué qu'il mettait du "Power clutch" sur Harley, ça marche aussi sur les Buell, l'embrayage devient du velours... entre 30 et 40% de moins. C'est un allemand qui a développé la pièce et a obtenu un prix pour son innovation...
http://www.partsmag.com/0503/Drag-Muller-Ed-0503/Drag-Muller-0503.html en fait la pièce dont tu parles est la pièce d'origine reproduite et allongée de quelques millimètres vu en vente sur site allemand ou autre.Le problème c'est qu'elle est beaucoups plus cher que la petite rallonge vissée que j'ai monté |
Nombre de messages : 33626 Age : 53 Localisation : bout du lac de G'nèv' Ma Buell : XB12S 04
seby
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mer 9 Juil 2008 - 16:35 | |
http://www.partsmag.com/0503/Drag-Muller-Ed-0503/Drag-Muller-0503.html en fait la pièce dont tu parles est la pièce d'origine reproduite et allongée de quelques millimètres vu en vente sur site allemand ou autre.Le problème c'est qu'elle est beaucoups plus cher que la petite rallonge vissée que j'ai monté Au fait Remy, j'y repenses, maintenant que j'ai récup la meule. Vu que ca fait une rallonge, du coup, ca veut dire que pour embrayer "autant" qu'avant il faut plus de course sur le levier, ce qui rend le levier + mou. Mais moi j'ai 2 problemes, levier trop dur, ET levier trop loin, trop de course. Du coup avec ce systeme je corrige 1 probleme mais j'empire l'autre, non? |
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique Mer 9 Juil 2008 - 18:45 | |
| - seby a écrit:
http://www.partsmag.com/0503/Drag-Muller-Ed-0503/Drag-Muller-0503.html en fait la pièce dont tu parles est la pièce d'origine reproduite et allongée de quelques millimètres vu en vente sur site allemand ou autre.Le problème c'est qu'elle est beaucoups plus cher que la petite rallonge vissée que j'ai monté Au fait Remy, j'y repenses, maintenant que j'ai récup la meule. Vu que ca fait une rallonge, du coup, ca veut dire que pour embrayer "autant" qu'avant il faut plus de course sur le levier, ce qui rend le levier + mou. Mais moi j'ai 2 problemes, levier trop dur, ET levier trop loin, trop de course. Du coup avec ce systeme je corrige 1 probleme mais j'empire l'autre, non? non je ne crois pas .En fait le réglage est plus précis à faire car l'espace ou tu débrayes est plus petit sinon une fois réglé je ne vois aucune différence avec l'ancien réglage et pourtant j'ai des petites mains.demandes l'avis à ceux qui ont mis la pièce ils n'ont pas eu de problème je pense de ce coté mais que des avis positifs c'est le jour et la nuit |
| Sujet: Re: [TUB][QUESTION]Embrayage Hydrolique | |
