| [tub] codes couleurs | |
+10titi28graal k-lagan boutdumonde buell-dog nico_vts LUNAR974 RoToR Nicolium Sebuell buellman626 14 participants |
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: [tub] codes couleurs Jeu 15 Mai 2008 - 20:25 | |
| Pris sur un autre site...
2001
Color PPG Paint Code For All Colors Four parts clear to 1 part hardener to 11/2 parts reducer. Spray 1 drop coat over whole part then apply 2 wet coats over entire part.
*Molten Orange White Base coat DBC-91853 apply under orange top coat.
**Reducer depends on temperature. Contact your PPG dealer for assistance.
Reactor Yellow DBC-84218 Clear DCU-2042 Carbon Black DBC-9700 Hardener DCX-9 Blue Streak DBC-190388 Reducer** DT-870 Molten Orange DBC-61876* DT-885 Volcano Grey DBC-28328 DT-895 Note: Mix with reducer, spray 3 coats.
2000
Reactor Yellow DBC-84218 Clear DCU-2042 Carbon Black DBC-9700 Hardener DCX-9 Demon Blue DBC-191308 Reducer** DT-870 Red Snap DBC-75050 DT-885 Blue Streak DBC-190388 DT-895 Molten Orange DBC-61876* Amazon Green DBC-48449 Billet Metallic DBC-36571 Note: Mix with reducer, spray 3 coats.
1999
Onyx Alloy DBC-95152/32 Clear DCU-2042 Spark Red DBC-75708 Hardener DCX-9 See 2000 for: Reducer** DT-870 Molten Orange Red Snap DT-885 Reactor Yellow Blue Streak DT-895 Carbon Black Amazon Green Billet Metallic Demon Blue Note: Mix with reducer, spray 3 coats.
1997-1998
Color PPG Paint Code For All Colors The paint used for the 1997-98 colors is PPG and is a DAU base coat (this will make sense to a PPG dealer who will be mixing the paint). The clear coat used is PPG DCU-2020.
Canyon Red DBC-75049 Clear DCU-2042 Black Magic DBC-95055 Hardener DCX-9 Spark Red DBC-75708 Reducer** DT-870 Red Snap DBC-75050 DT-885 Blue Streak DBC-190388 DT-895 Molten Orange DBC-61876* Amazon Green Metallic DBC-48449 Billet Metallic DBC-36571 White Gold-Base DBC-91679 White Gold-Top Coat DBC-91680 Ice White Pearl ('98) See 1996 Formula Note: Mix with reducer, spray 3 coats.
1995-1996 Black Sapphire 1. Spray 3 coats Sikkens 400 Black Base. 2. Mix 27 grams of House of Color PP5 Prism Pearl Blue with on full liter of Sikkens 666 Binder. Spray 3 coats. 3. Spray 3 coats Sikkens Autoclear. Production paint for these years was supplied by Sikkens. The following formulas should allow a Sikkens dealer to mix paint that will match the Buell factory color.
Red Snap 1. Spray 3 coats Ford 87-88 color code FA87:RS. 2. Spray 3 coats Sikkens Autoclear.
Yellow Jacket Pearl 1. Spray 3 coats Sikkens 297 Base. 2. Spray 3 coats Sikkens SEC Honey Yellow Pearl. 3. Spray 3 coats Sikkens Autoclear.
Ice White Pearl 1. Spray 3 coats Sikkens 00 Base. 2. Mix 2 parts Sikkens 333PB with 1 part Sikkens 666 Binder. Spray 3 coats. 3. Spray 3 coats Sikkens Autoclear.
Carribean Candy Blue 1. Spray 3 coats Sikkens 333 FC. 2. Mix 10% Sikkens 261 with 90% Sikkens 666 Binder. Spray 3 coats. 3. Spray 3 coats Sikkens Autoclear.
Quicksilver Metallic 1. Mix:
Sikkens 333cc 367.7 gr Sikkens 971 375.9 gr Sikkens 261 387.6 gr Sikkens 00 424.6 gr Sikkens 777 507.3 gr Sikkens 744 656.1 gr Sikkens 666 903.8 gr
2. Reduce with 1 part paint and 1 part Sikkens 123 reducer. Spray 3 coats. 3. Spray 3 coats Sikkens Autoclear.
Parkway Blue 1. Mix:
Sikkens 332va 313.2 gr Sikkens 777 326.8 gr Sikkens 333c 341.2 gr Sikkens 956 411.8 gr Sikkens 216 502.0 gr Sikkens 666 689.8 gr Sikkens 971 968.2 gr
Canyon Red 1. Mix:
Sikkens 332pr 359.3 gr Sikkens 666 556.1 gr Sikkens 528 722.5 gr Sikkens 568 869.4 gr Sikkens 956 954.6 gr Sikkens 538 979.1 gr
Carbon Black 1. Reduce with 1 part Sikkens 400 and 1 part Sikkens 123 reducer. Spray 3 coats. 2. Spray 3 coats Sikkens Autoclear.
High Voltage Yellow 1. Spray 3 coats Sikkens 297 yellow base. 2. Spray 3 coats House of Color 501 Neon. 3. Spray 3 coats Sikkens Autoclear.
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | |
Nicolium
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Jeu 15 Mai 2008 - 21:28 | |
| Super !!  |
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Sam 29 Nov 2008 - 23:35 | |
| http://k-wallbaum.homepage.t-online.de/my/down/Paint.pdf |
LUNAR974
Nombre de messages : 15 Age : 40 Localisation : reunion Date d'inscription : 16/04/2009
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Ven 17 Avr 2009 - 23:11 | |
| t aurais pas les codes couleurs 2006 stp? |
nico_vts
Nombre de messages : 15 Localisation : Dangé (86) Ma Buell : X1 white lightning Date d'inscription : 23/04/2010
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Mer 23 Juin 2010 - 13:55 | |
| je cherche le code couleur de ma X1 white lightning de 2000, quelqu'un sait ça? |
buell-dog
Nombre de messages : 10 Date d'inscription : 15/12/2012
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Dim 13 Jan 2013 - 20:27 | |
| salut à tous, si ça peut aider j'ai trouvé un site pour acheter la peinture de type d'origine, voici le liens si ça peut aider. par contre j'ai jamais commandé là bas donc je ne connais pas la qualitée, mais le prix est plus que correct. http://www.rsbikepaint.com/fr-fr/colours.php#makeid=23&modelid=658&prodyear=2001 y a plus qu'a trouver |
boutdumonde
Nombre de messages : 2016 Age : 45 Localisation : Presque à Rennes 35 Ma Buell : La plus belle
la plus jolie
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Dim 17 Mar 2013 - 22:09 | |
| du deterrage oui ! mais c'est important.
y a t-il une correspondance en RAL de la couleur rouge de ma X1 Racing Stripe ???
s'il vous plait.
merci d'avance. |
buell-dog
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Dim 17 Mar 2013 - 22:20 | |
| il faudrait que tu compars une pièce de ta moto avec le teintier RAL et voir s'il y a une correspondance |
boutdumonde
la plus jolie
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Dim 17 Mar 2013 - 22:28 | |
| je suis daltonien et je prefererai avoir l'avis d'un buelliste.
en fait non je vois bien mais si je peux eviter de demonter un morceau pour aller chez un pro.... |
buell-dog
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Lun 18 Mar 2013 - 7:16 | |
| ou bien tu démonte rien et tu y va avec la moto complète, ça fait faire un petit tour en plus |
boutdumonde
la plus jolie
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Lun 18 Mar 2013 - 7:49 | |
| J'habite en Bretagne, ici c'est la saison des pluies. |
Nombre de messages : 2193 Age : 38 Localisation : Orvault (44) Ma Buell : Ex XB9S Full Race & X1 en cours de modif et S3/1 bitza racer
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Lun 18 Mar 2013 - 21:04 | |
| Merde c'est con j'ai un spectrophotomètre au taf, pour flasher les teintes. Si tu passes par Nantes je te fais ça. Sinon je vais voir si y a pas une correspondance chez les constructeurs auto et ral. Je regarderai ça demain. C'est con car j'ai les teintes Buell |
boutdumonde
la plus jolie
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Lun 18 Mar 2013 - 21:42 | |
| Merci c'est cool, mais bon j'ai deposé aujourd'hui ma boucle arriere de X1 dans la boutique pour un thermolaquage en rouge je sais plus quoi.
j'espere que ça va pas etre dégeulasse.
Nombre de messages : 1564 Age : 49 Localisation : Chartres Ma Buell : (Buell XB12STT converti SS 2007) vendu
FXDB pour monsieur
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Mer 6 Juil 2016 - 21:32 | |
| salut Un cadre et des jantes S1 ou X1 white, c'est quoi la couleur ? (ne repondez pas blanc s'il vous plais  ) Ice White Peal ? |
FXDB pour monsieur
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Jeu 7 Juil 2016 - 10:02 | |
| Merci Mc Mais il n'est pas dans la liste celui là. Aurais-tu une reference ou une correspondance ? |
Nombre de messages : 5209 Age : 43 Localisation : sud champagne Ma Buell : S1L '97,XB9'05,mon ex X1'01 et ex XB12S '08 US Date d'inscription : 27/02/2008
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Lun 28 Nov 2016 - 14:17 | |
| Au SECOURS!!! J'arrive pas a trouver la correspondance RAL pour le Billet Metallic DBC-36571 ( couleur du cadre des S1 97') faisant une époxy....ce code couleur n'est pas possible, RAL obligatoire Merci a vous
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Lun 28 Nov 2016 - 16:44 | |
| ah oui titanium. tu as raison Mc. ben je vais trouver un RAL se rapprochant le plus alors
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Mar 29 Nov 2016 - 15:31 | |
| Le RAL le plus proche des cadres gris des S1 (titanuim) c'est le RAL 9023 - Pearl Dark Grey.(donc Gris foncé nacré) Ca sera la couleur de mon cadre désormais.  ![[tub] codes couleurs Ral-9010](https://i.servimg.com/u/f37/16/97/48/60/ral-9010.png) |
Moun17
Nombre de messages : 483 Age : 39 Localisation : saintes Ma Buell : xb12s
http://buell.actifforum.com/t46005-mon-xb12s-2009#927722 Date d'inscription : 08/04/2018
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Mar 24 Avr 2018 - 7:57 | |
| bonjour, moi je cherche partout le code couleur du blanc
j'ai des carénages pour mon xb12s et je voudrais les faire repeindre en blanc
Merciiiii
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Mar 24 Avr 2018 - 9:20 | |
Moun17
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Mar 24 Avr 2018 - 10:38 | |
| Je voulais un blanc brillant.. J avais vu le lien mais pas trouvé réponse |
jerry
Nombre de messages : 281 Age : 43 Localisation : 57 Thionville Date d'inscription : 07/06/2008
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs Jeu 3 Jan 2019 - 12:46 | |
| Bonjour à tous, je viens d'acheter une X1, elle est bleue (bleu viper). Pensez vous que ce soit d'origine ?  ,j'en ai jamais vu à part sur google photos (site US). Merci. |
![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | Sujet: Re: [tub] codes couleurs ![[tub] codes couleurs Empty](https://2img.net/i/empty.gif) | |
