hello
Apparemment non
voila la réponse
vendredi 13 juillet, 08:36 (il y a 2 jours)
Assurer un Suivi
De :
Julian van Dijken
A :
'marcguiraud@sfr.fr'
Hello Marc,
Thank you, it looks like the seals need to be replaced. I also recommend replacing the bearing inside the carrier as the dirt has probably worn out due to this.
The damper needs to be opened up to replace that bearing and seals, so I would recommend rebuilding the shock.
Cost for rebuilding is €115,- ex VAT. The bearing is €10,- ex VAT and seals are included in rebuild price.
Let me know if you require any further information,
With kind regards,
Julian van Dijken
Technical Engineer
Sig
