Nike : Jusqu’à 50% sur les articles de ...
 Installer les leviers Pazzo
fred
trob
8 participants
Nombre de messages : 6994
Installer les leviers Pazzo Empty
MessageSujet: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 13:08
Jai trouvé ce lien avec les instructions et photos cheers
pour les nazes en mécaniques comme moi ça pourra être utile. Ce week end , jm'y mets
bon cest en anglais Razz mais pas grave !!
Ok, once the drool slows to a trickle get your tools and get started. You'll need:
1/4" drive 10mm socket
1/4" drive ratchet (small one)
1/4" drive extension with ball end or flex adapter
Flat blade screw driver
Blue Loctite
Lithium grease
On the brake side loosen and remove the pivot shaft nut on the bottom of the control. Pull the brake lever and see where it pivots. It's on the shaft with the slot for a screw driver on top. The nut is on the bottom side on that shaft.
Installer les leviers Pazzo IMG_0854
With the nut removed use a flat blade screw driver to remove the pivot shaft. Once it's backed out of the threads hold the brake lever and pull the shaft out.
Installer les leviers Pazzo IMG_0856
Apply a little lithium grease to the shaft.
Installer les leviers Pazzo IMG_0857
Line the Pazzo brake lever up with the shaft hole and start threading the shaft in with your fingers.
Installer les leviers Pazzo IMG_0861
Tighten the shaft with the screw driver.
Installer les leviers Pazzo IMG_0862
Ok, Pazzo's instructions didn't call for Loctite but I like to put it on anything I take loose... so I put some on the pivot shaft nut. If you don't want to, don't... but don't come cryin' when it vibrates off. Installer les leviers Pazzo 506615
Installer les leviers Pazzo IMG_0863
Start the pivot shaft nut by hand and then tighten it up. All that's left to do on this side is set the lever where you want it using the adjuster lever.
Installer les leviers Pazzo IMG_0864
If you want to, you can take a break and drool over the look of the newly installed Pazzo brake lever. 👍 Or you can go ahead and do the clutch and drool when you've finished both.
On the clutch side remove the pivot shaft nut with the 10mm socket, a short extension with ball/flex end, and the smallest 1/4" drive ratchet you have. The clutch side is a bit tricky. The clearance around the nut is close and it takes some finger fuggin' to get the socket onto the nut. I found that it was easier to put the socket onto the nut first, then put the extension into the socket. The Pazzo instructions say that you can ease installation by marking where your controls are, loosening the clip-ons and rotating the clutch lever up, then once the new lever is installed rotate it back down to match your mark and tighten everything back down. I didn't find it necessary to do that but it might make it a bit easier if you're having problems the way I done it. Here's a pic of me removing the clutch side nut.
Installer les leviers Pazzo IMG_0865
The shaft on the clutch side is not threaded in. Once the nut is off push the shaft up from the bottom, grab it and just pull it out.
Installer les leviers Pazzo IMG_0866
Now loosen the clutch cable tensioner to give yourself some slack in the clutch cable. The tensioner is the big silver thing on the cable with the little loop looking bracket against it. Hold the loop away from the adjuster and turn it so that it gets closer to the clutch lever. This puts slack in the cable. Once you've run the adjuster all the way in, rotate the clutch lever around and remove the cable end from it. Just line the cable up with the slot in the lever and pull it out and put it into the Pazzo lever.
Installer les leviers Pazzo IMG_0867
Align the pivot shaft hole and put the shaft back in. It is machined so that it sits in the hole in one position only. Make sure you get it fully seated and then start the nut on the bottom by hand while you hold the shaft in place and then tighten it with the ratchet/extension/socket combo. Again I used blue Loctite.
Installer les leviers Pazzo IMG_0869
Adjust the clutch cable play and then drool some more. Then get on the bike and [play with the lever positions until you get them where you like 'em.
Installer les leviers Pazzo IMG_0874
Installer les leviers Pazzo IMG_0875
trob
trob
Nombre de messages : 934
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 18:47
Très bien ce petit tuto. A mettre dans la base je pense.
Merci Wink
Nombre de messages : 5146
Ma Buell : ex XB12S 2005,ex XB 12R 2007, now 1125RR pistarde Teigne 3.0
et MV Turismo Veloce RC
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 20:27
sauf que c est en anglais et pour une kawa Installer les leviers Pazzo 506615 Installer les leviers Pazzo 506615 Installer les leviers Pazzo 506615
fred
fred
Nombre de messages : 1669
Ma Buell : XB12S 2005
+1000VTRF
+1000VTRS
+650NX version puzzle
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 22:14
coup de bol que les explications soient pas en ping pong... Installer les leviers Pazzo 506615
Nombre de messages : 8540
Ma Buell : poum poum
ciao Marco ! ...
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 22:30
Shocked Un tuto pour changer des leviers Question
Les motards du XXI ème siècle seraient à ce point loins de leur machine Question (à part sur les terrasses de café Installer les leviers Pazzo 506615 )
PAZ
PAZ
Nombre de messages : 625
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 22:51
a quand le tuto pour demarer la moto Question Question Question
pingouin
pingouin
Nombre de messages : 1062
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 22:53
+1 a ce niveau ca craint Twisted Evil Wink
Nombre de messages : 22271
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 23:11
Tiens scratch on avait pas volé les leviers de quelqu'un dernièrement ?
ciao Marco ! ...
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyMer 13 Juin 2007 - 23:14
Oui, des noirs avec les molettes reglages or...
MessageSujet: Re: Installer les leviers Pazzo   Installer les leviers Pazzo EmptyJeu 14 Juin 2007 - 10:14
ehh tout le monde nai pas si balaise que vous les gars, et certains ont peut etre des craintes à toucher leur machine dès quil sagit de changer des pièces.
En tout cas, je pensais en etre capable et en voyant ce tuto confirme ce que je pensais.
ben en fait ouais cest archi simple ! je les ai monté hier soir en 10 minutes LOL !!!
deux trucs a dévisser et revisser et cest parti.
» Leviers PAZZO et TITAX
» Comment Installer ECMSPY
» installer son echappement race
» Leviers
» Leviers
