-28%
PNY CS900 Series – Disque SSD 1 To 2,5″ SATA III à 71,99€
71.99 € 99.99 €
 Urgent help needed: who used EcmSpy on a BUE2D ECM?
svbagoo
id073897
6 participants
id073897
Nombre de messages : 54
Urgent help needed: who used EcmSpy on a BUE2D ECM? Empty
MessageSujet: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyDim 25 Mar 2012 - 20:52
Sorry mates to bother you with dull questions: anyone here who has ever adjusted a BUE2D ECM with EcmSpy for Mono? Please be so kind then and drop me a mail to gunter(at)ecmspy.com.
Thanks a lot!
http://www.ecmspy.de
svbagoo
svbagoo
Nombre de messages : 3502
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyDim 25 Mar 2012 - 21:26
Hello, i only ajust whith ecmspy for a 2003 at 2007 whith megalogwiewer . What would you ajust on your Bue2D ecm ?
Nombre de messages : 31536
Urgent help needed: who used EcmSpy on a BUE2D ECM? 506615
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyLun 26 Mar 2012 - 11:25
Je traduis le message de Günter, le "papa" d'ECMSpy, ce serait cool si quelqu'un avait la réponse qu'il cherche :
"est-ce que quelqu'un a déjà ajusté sa cartographie sous BUE2D avec ECMSpy for mono ?"
t.s
Nombre de messages : 137
Ma Buell : 1125 CR 09
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyLun 26 Mar 2012 - 13:58
just burned a bue2d with ecmread, without adjustment, will this help?
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyLun 26 Mar 2012 - 16:59
Faut lui envoyer un mail, il se connecte pas trop sur ce forum Wink
Totoche38
Totoche38
Nombre de messages : 2153
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyLun 26 Mar 2012 - 19:25
Réponse de GUnter :
Hello,
thanks for the reply.
Did you ever change any settings in your ECM and were these changes still
present after you switched off ignition?
Thanks & regards,
Gunter
Avec aide google,
Avez-vous jamais modifier les paramètres de votre ECM et étaient ces changements encore
présenter après avoir éteint allumage?
Si quelqu'un comprend mieux la question que moi, peut-il m'expliquer le Pb?
flower flower
BuHell
BuHell
Nombre de messages : 3245
Ma Buell : M2 MK I / Ural 750
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyLun 26 Mar 2012 - 19:51
Totoche38 a écrit:
Réponse de GUnter :
Hello,
Thanks & regards,
Gunter
Avec aide google,
flower flower
Avez vous déjà modifié les paramètres de votre ECM . et les changements sont ils restés enregistrés après coupure du contact (et réallumage je suppose)
Totoche38
Totoche38
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyLun 26 Mar 2012 - 20:20
Donc je m'apprête à lui répondre que :
J'ai changé les paramètres de la valve à l'échappement et la carto d'avance du cylindre arrière.
j'ai du écrire toute l'Eprom pour mémoriser ces valeurs dans l'ECM.
flower flower
BuHell
BuHell
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyLun 26 Mar 2012 - 21:05
flower flower
Ca doit donner qque chose comme :
I changed my valve and rear cylinder settings. I have totaly re-write the EPROM to actually memorise the changes in my ECM
id073897
MessageSujet: Re: Urgent help needed: who used EcmSpy on a BUE2D ECM?   Urgent help needed: who used EcmSpy on a BUE2D ECM? EmptyMar 27 Mar 2012 - 22:01
Problem solved. Thanks a lot for your support!
» Très URGENT, Très URGENT, j'ai besoin d'un Alsacien
» ecmspy svp c'est urgent
» URGENT-Besoin de ECMSPY sur Toulouse
» URGENT URGENT recherche quelqu un sur Panam
» [XB] Carto stock BUE2D s'il vous plaît =)
