| Nouvelle version d'ECMSPY! | |
Nombre de messages : 3574 Age : 44 Localisation : A 20 minutes de tours... au sud. Ma Buell : XB12Ss - S
650 KLX supermot'-- vendue
Ducati S4R-- vendue
R1 2003 -- vendue aussi...
| Sujet: Nouvelle version d'ECMSPY! Mar 28 Mai 2013 - 22:58 | |
| hello tout le monde les gens !
je viens de recevoir un mail de gunter, le papa d'ecmspy.
"Hello, this mail is to inform you that a new version of EcmSpy for Mono (Version 2.0.29.1) is available for download. This version got several new features added, please refer to the user guide (http://ecmspy.com/ug_mono/V2.0/userguide_mono.shtml) for a more detailed description of the application and the installation process. New features worth mentioning are: - EEPROM data can now fetched and saved to file from any supported ECM, as well as read from file and burnt into the ECM, even with no ECM specific database installed - additionally, trouble codes can be fetched, displayed and cleared from any supported ECM - also without ECM specific databases available, runtime data can be displayed or recorded to a log file for any supported ECM - FTDI cable users can now connect directly to the cable's USB port, without the necessity to set up a virtual COM port These features have been implemented to aid EcmSpy users with providing help to other Buell owners. Please note that you must also install the latest version of the databases, as the new release will not be working with the previous version of the databases. Application and database installers for your activated ECM types (BUEZD BUE2D/B3R2D), in regard to your activation request 1359737666-541, are ready for download in your personal download area. Please log into your personal download area, download and run the installers (application first) to ensure correct operation of the software. To access your download area you will need your login credentials as provided with the registration mail. DO NOT REMOVE OR UNINSTALL THE PREVIOUS VERSION OF YOUR SOFTWARE, AS THIS WILL IMMEDIATELY INVALIDATE YOUR ACTIVATION KEY! The new release has been thoroughfully tested and will run on Windows 7 and Windows 8 as well as the older version like Windows Vista. This release will fetch and burn EEPROM data (as a replacement for EcmRead) and also allows to watch and record runtime data for troubleshooting, even without a ECM specific database installed. Binary logfile conversion, formerly provided by the Bin2Msl or Bin2Log application, is now an integral part of EcmSpy too. Large parts have been rewritten for better maintainability, and the graphical interface has been reorganized carefully for better usability. Please note also that this version requires a working Mono Version 2.10 runtime environment before installing the EcmSpy for Mono application. Kind regards, Gunter "
en francais, enfin traduction approximative de goooooogle :
"Bonjour, ce courrier est de vous qu'une nouvelle version de EcmSpy pour Mono (Version informer 2.0.29.1) est disponible en téléchargement. Cette version a obtenu plusieurs nouvelles fonctionnalités ajoutées, veuillez consulter le mode d'emploi (Http://ecmspy.com/ug_mono/V2.0/userguide_mono.shtml) pour une analyse plus détaillée description de l'application et le procédé d'installation. Nouvelles fonctionnalités digne de mention sont les suivants: - Données de l'EEPROM peuvent maintenant récupéré et sauvegardé dans un fichier à partir de n'importe quel ECM pris en charge, ainsi que de lire le fichier et brûlé dans l'ECM, même sans ECM spécifique base de données installée - En outre, les codes de panne peuvent être récupérés, affichés et dégagé de toute soutenu ECM - Également sans bases de données spécifiques ECM disponibles, les données d'exécution peuvent être affichées ou enregistrés dans un fichier de log pour toute prise en charge ECM - Les utilisateurs FTDI câble peuvent désormais se connecter directement au port USB du câble, sans la nécessité de mettre en place un port COM virtuel Ces caractéristiques ont été mises en place pour aider les utilisateurs EcmSpy à fournir de l'aide à d'autres propriétaires de Buell. Veuillez noter que vous devez également installer la dernière version des bases de données, la nouvelle version ne travaillera pas avec la version précédente des bases de données. Application et installateurs de base de données pour vos types ECM activés (BUEZD BUE2D/B3R2D), en ce qui concerne votre demande d'activation 1359737666-541, sont prêts pour téléchargement dans votre zone de téléchargement personnelle. S'il vous plaît vous connecter à votre personnel zone de téléchargement, téléchargez et exécutez les installateurs (première application) pour assurer fonctionnement correct du logiciel. Pour accéder à votre espace téléchargement, vous aurez besoin vos informations de connexion dans les conditions prévues à l'e-mail d'inscription. NE PAS supprimer ou désinstaller la version précédente de votre logiciel, car cela IMMÉDIATEMENT annuler votre clé d'activation! La nouvelle version a été thoroughfully testé et fonctionne sur Windows 7 et Windows 8 ainsi que l'ancienne version comme Windows Vista. Cette version extraire et graver des données EEPROM (en remplacement de EcmRead) et également permet de regarder et d'enregistrer les données d'exécution pour le dépannage, même sans ECM spécifique base de données installé. conversion de log binaire, autrefois fourni par l' Bin2Msl ou l'application Bin2Log, fait désormais partie intégrante de EcmSpy trop. Grand parties ont été réécrites pour une meilleure maintenabilité, et le graphique interface a été réorganisé avec soin pour une meilleure ergonomie. Veuillez noter également que cette version nécessite une version mono de travail 2.10 environnement d'exécution avant d'installer le EcmSpy pour l'application Mono. Cordialement, Gunter"
voila voila !
pour info, je prend mon pc avec ECMSPY / ECMSPY for mono / ECMREAD / megalogviewer aux ABD + câble, j'ai quelques cartos dessus, ainsi que la licence pour BUEZD / BUE2D, le tout gentillement amené par madame ZIRAX.
Marco 45
| Sujet: Re: Nouvelle version d'ECMSPY! Jeu 6 Juin 2013 - 7:36 | |
| super !!!
seule truc galère pour ceux qui comme moi ont un vrai problème avec l'anglais c'est que ecmspy formono ne proposait plus le français
a-t-il remis cette option dispo ? sinon ce serait super de le remonter car je pense que ça ne doit pas être très compliqué
by |
Ducati S4R-- vendue
| Sujet: Re: Nouvelle version d'ECMSPY! Jeu 6 Juin 2013 - 8:14 | |
| ouiap, mais non... je lui ai déjà envoyé un mail, lui expliquant que son logiciel est vraiment bien, que c'est un plus pour les utilisateurs de buell, mais que les non-anglophones on des problème, surtout avec les termes technique.
Nombre de messages : 742 Age : 43 Localisation : Châlons en Champagne Ma Buell : XB12SS Cherry Bomb 2009 Date d'inscription : 17/04/2019
| Sujet: Re: Nouvelle version d'ECMSPY! Ven 7 Juin 2019 - 22:40 | |
| C’est vraiment compliqué pour avoir la version « payante » de ce logiciel. Je m’explique, j’ai téléchargé et installé la démo de ecmspy for mono et j’ai donc la clé publique, avec cette clé je suis allé activé la version payante avec donation et le logiciel me demande d’attendre en faisant un don. Le problème c’est qu’il n’y a aucun lien pour faire ce fameux don! Je commence à devenir fou, 2h que je tourne en rond sur ce site né anglais sans aucun lien pour s’enregistrer ni aucun lien pour le don... Si une âme charitable pouvait me donner la solution... |
| Sujet: Re: Nouvelle version d'ECMSPY! Sam 8 Juin 2019 - 23:41 | |
| faut remplir le formulaire en bas de cette page, une fois que tu as fait tout le processus d'activation d'ECMspy "démo", avec génération de la clé publique, etc... http://www.ecmspy.com/cgi-bin/activation2.cgi
vu que tu n'as droit qu'à un type d'ecm par don de 50£, faut pas te gourer de modèle. Inversement, tu peux en valider plusieurs en versant X fois 50£
pour faire le don, faut cliquer sur le lien en bleu en bas du tableau de prix "JustGiving", ce qui ouvre une page pour effectuer le don.(attention à la monnaie, le don est à faire en GBP le site risque de te mettre en dollar par défaut)
une fois le formulaire rempli, tu cliques sur "Submit" et en retour, tu vas avoir un fichier PDF à enregistrer, le formulaire d'activation ou "activation document" qui contient l'activation ID, en cliquant sur le lien rouge "click here to download your activation document"
ça, c'est le document PDF que tu dois enregistrer :
et si le don est fait, l'activation est faite dans l'heure.
pour avoir la version full, il faut retourner dansl'onglet "donwload" du site ECMSPY et entrer l'activation ID dans la case dévolue. C'est pas précisé, mais je suis certain que le lien entre le don et l'activation passe par l'adresse IP de l'ordinateur, et donc qu'il faut faire le don avec l'ordi qui fera tourner ECMSpy. |
| Sujet: Re: Nouvelle version d'ECMSPY! Dim 9 Juin 2019 - 1:30 | |
| Ah merci MC, je m’en occupe et je te dis si ça marche |
| Sujet: Re: Nouvelle version d'ECMSPY! Lun 10 Juin 2019 - 18:37 | |
| Bon voilà mon problème, j’ai bien suivi la procédure d’activation sans faire de donation car en cliquant sur SUBMIT ils m’ont validé avec ce message: Du coup j’hésites à aller faire un don sur le lien bleu en bas du tableau que tu m’as indiqué MC car j’ai peur de payer dans le vent et qu’il ne sache pas qui a fait le don |
Nombre de messages : 958 Age : 46 Localisation : Granville / Rouen / Sables d'Olonne Ma Buell : XB12 SS 2006
1125CR 2009
XB12R 2004 RSS
XB12R 2007
S1 Lightning 1997 Date d'inscription : 16/07/2017
| Sujet: Re: Nouvelle version d'ECMSPY! Lun 10 Juin 2019 - 18:57 | |
- faut remplir le formulaire en bas de cette page, une fois que tu as fait tout le processus d'activation d'ECMspy "démo", avec génération de la clé publique, etc...
C'est pas précisé, mais je suis certain que le lien entre le don et l'activation passe par l'adresse IP de l'ordinateur, et donc qu'il faut faire le don avec l'ordi qui fera tourner ECMSpy. Avec l'ordinateur ou la même ligne internet ? IP publique ou mac adress donc ? |
| Sujet: Re: Nouvelle version d'ECMSPY! Lun 10 Juin 2019 - 19:01 | |
| J’ai tout fait avec le même ordinateur et la même box internet
Je viens à l’instant de faire la donation de 50 livres sterling et j’ai eu un numéro de don mais je ne sais pas quoi en faire. |
Nombre de messages : 1877 Age : 65 Localisation : Eure et loir Ma Buell : XB12X ULYSSES 2006 Date d'inscription : 26/02/2015
| Sujet: Re: Nouvelle version d'ECMSPY! Ven 5 Juil 2019 - 23:15 | |
| C'était plus facile de régler un carbu : Un tournevis et 2 gicleurs |
boutdumonde
Nombre de messages : 2122 Age : 47 Localisation : Presque à Rennes 35 Ma Buell : La plus belle
la plus jolie
| Sujet: Re: Nouvelle version d'ECMSPY! Mer 5 Aoû 2020 - 21:51 | |
| Je déterre le post, J'arrive à me connecter à mon 1125 avec ECMSPY version 2.0.31.2. Faire les tests fonctionne. Je n'arrive pas à modifier l'AFV , je pense qu'il s'agit d'un probleme de licence ou activation mais pas certain. Comment obtenir l'activation ou faire en sorte que cela fonctionne. Je ne trouve rien sur le site, peut etre meme l'activation n'est plus necessaire. http://buell.actifforum.com/t47446-ecmspy-activationMerci par avance. |
boutdumonde
la plus jolie
| Sujet: Re: Nouvelle version d'ECMSPY! Jeu 6 Aoû 2020 - 9:33 | |
| Nouvel essai ce matin,
Je pense qu'il me manque les bases de données.
Comment obtenir les bases de données ?
Je ne trouve rien sur le site. |
| Sujet: Re: Nouvelle version d'ECMSPY! | |
