| D un stock a un race..... au travail | |
+8McGyver Kronenbuell67 alain-xb12ss fred2a Rit heyoka Humberto jppons 12 participants |
jppons
Nombre de messages : 177 Age : 42 Localisation : RENNES Date d'inscription : 06/02/2009
 | Sujet: D un stock a un race..... au travail Dim 15 Mar 2009 - 13:54 | |
| J ai trouvé ça sur un forum de l oncle Sam. Qui se lance? Si vous voulez, j ai les instructions, bien sur en ricain !!!! Mais les photos suffisent a comprendre je pense. What you'll need: se que vous aurez besoin... je ne traduirai que ça.. Materials: 1) Stock muffler 2) Stainless Steel mesh (found it on eBay) 3) Coarse Stainless Steel Wool (also found on eBay) 4) Welding/Brazing Flux 5) Welding/Brazing Rods (1620 degree, white rods) 6) Two - 2" chrome exhaust tips ($10 each at AutoZone) Tools: 1) Torx-head wrench set 2) Deep-well socket set 3) Dremel cutting tool 4) Die-Grinder 5) Jigsaw with metal blade 6) Welding/Brazing equipment 7) 2-1/8" or 2-1/4" hole saw The welding equipment can be MIG, TIG, or Oxy Acetylene. Whatever you have on hand should do. I actually bought one of those Oxy/MAPP welding/brazing kits at Lowes for $50. It's the one that has the small red and yellow tanks. It worked well, but went through about three of the Oxy tanks, at $8 a piece. I used the white 1620 degree rods. While I think this is technically considered "Brazing", if you're exhaust gas ever gets hot enough to re-melt the joints, you've probably already blown your motor.                       Et voila un echappement pour presque rien et qui ressemble comme deux gouttes d eau a un race Voila le son, terrible... je vous laisse ecouter http://www.atvcolorado.com/attachments/Buell/Exhaust/Exhaust.wma |
Nombre de messages : 7012 Age : 47 Localisation : ninety four Date d'inscription : 06/05/2007
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 14:32 | |
| joli boulot !!!  |
heyoka
Nombre de messages : 986 Age : 61 Localisation : 62 Ma Buell : BELL X1 (1999) Date d'inscription : 11/06/2008
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 15:22 | |
| J'avais pratiqué un peu ce genre de modif en 93 sur le Mostro , découpage au niveau de la soudure Ar. on enléve le "Manchon" alu ensuite coupure à l'autre extrémité et vidage du corps de pot pour y remettre une taule percée roulée en tube avec laine de roche autour pour l'absortionet ressoudage en sens inverse ce qui garde l'aspect d'origine avec un bon rendement et du poids en moins , une bonne alternative pas chere si on bricole  |
Rit
Nombre de messages : 141 Age : 38 Localisation : IDF 92 Date d'inscription : 03/02/2009
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 18:52 | |
fred2a
Nombre de messages : 2198 Age : 42 Localisation : corse du sud Ma Buell : XB12S 2008 racing paint stripes Date d'inscription : 25/11/2007
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 18:58 | |
| interessant comme topo, un modo pourrait le mettre dans une base de donnée |
alain-xb12ss
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 19:16 | |
| en effet , superbe son  |
fred2a
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 19:21 | |
Kronenbuell67
Nombre de messages : 4545 Age : 36 Localisation : Alsace Ma Buell : Béhèmvé S1000RR 2013
Speed triple 1050 R 2012 fullmotherfuckingpowa & XB12S White'n'Red du padre  Date d'inscription : 05/02/2008
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 20:01 | |
jppons
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 20:02 | |
Kronenbuell67
 | Sujet: Re: D un stock a un race..... au travail Dim 15 Mar 2009 - 20:08 | |
Nombre de messages : 31546 Age : 51 Localisation : bout du lac de G'nèv' Ma Buell : XB12S 04
Nombre de messages : 2452 Age : 37 Localisation : ALSACE haguenau 67 Ma Buell : S1 white lightning Date d'inscription : 13/11/2006
 | Sujet: Re: D un stock a un race..... au travail Lun 16 Mar 2009 - 12:39 | |
| et la valve dans tous ca elle devient quoi??
sinon c'est assé facile a réaliser... |
Jokers'smile
Nombre de messages : 331 Age : 37 Localisation : Orléans Ma Buell : XB 9SX 2007 en réparation Date d'inscription : 20/02/2008
 | Sujet: Re: D un stock a un race..... au travail Lun 16 Mar 2009 - 13:11 | |
caraiben
Nombre de messages : 812 Age : 53 Localisation : VAR Ma Buell : XB12STT 2008(US) Date d'inscription : 15/05/2008
 | Sujet: Re: D un stock a un race..... au travail Lun 16 Mar 2009 - 15:27 | |
| Genial le son  ça ronfle  |
jppons
 | Sujet: Re: D un stock a un race..... au travail Lun 16 Mar 2009 - 19:36 | |
| - guebes67 a écrit:
- et la valve dans tous ca elle devient quoi??
sinon c'est assé facile a réaliser... La valve à l air rebranché, donc pas de souci elle doit marcher normalement, enfin je pense. |
 | Sujet: Re: D un stock a un race..... au travail Mar 17 Mar 2009 - 18:23 | |
| ca doit etre comme meme pas mal comme modif.. je pense que le faite que tu garde la valve doit réduire la perte de couple a bas régime..
Personne ne voudrait essayé?? |
jppons
 | Sujet: Re: D un stock a un race..... au travail Mar 24 Mar 2009 - 22:26 | |
| Alors personne ne l a tenté ? Allez les gars !!!!! |
 | Sujet: Re: D un stock a un race..... au travail Mar 24 Mar 2009 - 22:34 | |
| si quelqu'un a un pot stock a sacrifier je veux bien lui faire la modif.. |
 | Sujet: Re: D un stock a un race..... au travail Mar 24 Mar 2009 - 22:39 | |
| - guebes67 a écrit:
- si quelqu'un a un pot stock a sacrifier je veux bien lui faire la modif..
Il y en a un à récupérer à Mulhouse  |
 | Sujet: Re: D un stock a un race..... au travail Mar 24 Mar 2009 - 22:42 | |
| c'est comme meme a plus de 2H de chez moi. sinon j'y serait bien allé pour te le récupérer. il est toujour a la poste? tu ne peut pas faire de démarche pour qu'il te le retourne? Car meme si je me rend sur place je n'est aucun document pour le récupérer... |
 | Sujet: Re: D un stock a un race..... au travail Mar 24 Mar 2009 - 22:50 | |
| - guebes67 a écrit:
- c'est comme meme a plus de 2H de chez moi. sinon j'y serait bien allé pour te le récupérer.
il est toujour a la poste? tu ne peut pas faire de démarche pour qu'il te le retourne? Car meme si je me rend sur place je n'est aucun document pour le récupérer... Non, il a bien était récupéré mais je n'ai pas été remboursé des FdP en retour ... et silence radio |
 | Sujet: Re: D un stock a un race..... au travail  | |
