-39%
Ordinateur portable ASUS Chromebook Vibe CX34 Flip
399 € 649 €
 [TUB] Reférence peinture
Nombre de messages : 33171
[TUB] Reférence peinture 506615
[TUB] Reférence peinture Empty
MessageSujet: [TUB] Reférence peinture   [TUB] Reférence peinture EmptyVen 5 Déc 2008 - 12:32
2001
Color PPG Paint Code For All Colors Four parts clear to 1 part hardener to 11/2 parts reducer. Spray 1 drop coat over whole part then apply 2 wet coats over entire part.
*Molten Orange White Base coat DBC-91853 apply under orange top coat.
**Reducer depends on temperature. Contact your PPG dealer for assistance.
Reactor Yellow DBC-84218 Clear DCU-2042
Carbon Black DBC-9700 Hardener DCX-9
Blue Streak DBC-190388 Reducer** DT-870
Molten Orange DBC-61876* DT-885
Volcano Grey DBC-28328 DT-895
Note: Mix with reducer, spray 3 coats.
2000
Demon Blue DBC-191308 Reducer** DT-870
Red Snap DBC-75050 DT-885
Blue Streak DBC-190388 DT-895
Amazon Green DBC-48449
Billet Metallic DBC-36571
1999
Onyx Alloy DBC-95152/32 Clear DCU-2042
Spark Red DBC-75708 Hardener DCX-9
See 2000 for: Reducer** DT-870
Molten Orange Red Snap DT-885
Reactor Yellow Blue Streak DT-895
Carbon Black Amazon Green
Billet Metallic Demon Blue
1997-1998
Color PPG Paint Code For All Colors The paint used for the 1997-98 colors is PPG and is a DAU base coat (this will make sense to a PPG dealer who will be mixing the paint). The clear coat used is PPG DCU-2020.
Canyon Red DBC-75049 Clear DCU-2042
Black Magic DBC-95055 Hardener DCX-9
Spark Red DBC-75708 Reducer** DT-870
Amazon Green Metallic DBC-48449
White Gold-Base DBC-91679
White Gold-Top Coat DBC-91680
Ice White Pearl ('9 See 1996 Formula
1995-1996
Black Sapphire
1. Spray 3 coats Sikkens 400 Black Base.
2. Mix 27 grams of House of Color PP5 Prism Pearl Blue with on full liter of Sikkens 666 Binder. Spray 3 coats.
3. Spray 3 coats Sikkens Autoclear.
Production paint for these years was supplied by Sikkens. The following formulas should allow a Sikkens dealer to mix paint that will match the Buell factory color.
Red Snap
1. Spray 3 coats Ford 87-88 color code FA87:RS.
2. Spray 3 coats Sikkens Autoclear.
Yellow Jacket Pearl
1. Spray 3 coats Sikkens 297 Base.
2. Spray 3 coats Sikkens SEC Honey Yellow Pearl.
Ice White Pearl
1. Spray 3 coats Sikkens 00 Base.
2. Mix 2 parts Sikkens 333PB with 1 part Sikkens 666 Binder. Spray 3 coats.
Carribean Candy Blue
1. Spray 3 coats Sikkens 333 FC.
2. Mix 10% Sikkens 261 with 90% Sikkens 666 Binder. Spray 3 coats.
Quicksilver Metallic
1. Mix:
Sikkens 333cc 367.7 gr
Sikkens 971 375.9 gr
Sikkens 261 387.6 gr
Sikkens 00 424.6 gr
Sikkens 777 507.3 gr
Sikkens 744 656.1 gr
Sikkens 666 903.8 gr
2. Reduce with 1 part paint and 1 part Sikkens 123 reducer. Spray 3 coats.
Parkway Blue
1. Mix:
Sikkens 332va 313.2 gr
Sikkens 777 326.8 gr
Sikkens 333c 341.2 gr
Sikkens 956 411.8 gr
Sikkens 216 502.0 gr
Sikkens 666 689.8 gr
Sikkens 971 968.2 gr
Canyon Red
1. Mix:
Sikkens 332pr 359.3 gr
Sikkens 666 556.1 gr
Sikkens 528 722.5 gr
Sikkens 568 869.4 gr
Sikkens 956 954.6 gr
Sikkens 538 979.1 gr
Carbon Black
1. Reduce with 1 part Sikkens 400 and 1 part Sikkens 123 reducer. Spray 3 coats.
High Voltage Yellow
1. Spray 3 coats Sikkens 297 yellow base.
2. Spray 3 coats House of Color 501 Neon.
[TUB] Reférence peinture Buell_10
» Peinture
» peinture
» Peinture
» peinture ou pas?...
» peinture qui s en va
BUELL PASSION INDEX :: BASE DE CONNAISSANCE :: Références de PIECES, MANUELS + LIENS utiles-
